I'm sure this topic has been covered before - although I DID do a search and could not find anything on it.
I recently went back to ATI for the 4870x2 after several generations of nVidia cards. Had no problems setting up SLI in the couple of instances I did do it. But typical of ATI drivers/software, setting up Crossfire has not gone as smoothly.
I have two Diamond 4870x2's - each card will work fine by itself running Catalyst 8.10 (so I know they're both fully functional). When shut down the system to add the second card and the Crossfire bridge - system will not boot up on next reboot. Computer boots up but screen is pitch black.
I have the LCD connected to the top card on the DVI plug closest to the motherboard. I've also tried moving it to any of the other three available plugs without anything showing up on the screen.
I'm sure it's something very basic I'm missing . . . anyone care to point me in the right direction?
Thanks!
Thanks!
