How should I clean my LCD screen?
belfert
I bought some anti-static wipes that are supposed to work on LCDs, but they leave streaks all over.
Any other suggestions on how to clean my LCD screen without wrecking it?
What I bought are 'Nice'n Clean Anti-Static Cleaning Wipes' I think from Walmart if anyone cares.
Brian Elfert
I have some monster screenclean, and they are great. Haven't tryed anything elses.
You know, a clean soft cloth and pure water (like bottled water) actually work very well on LCD surfaces, and it's cheap.
_____________________________________________________________
Windows Media Center 2005
Asus A8N32-SLI Deluxe Motherbaord
Athlon 64 X2 4800+
2GB Corsair 3500LL Pro Memmory
2x BFG 7800 GTX 512 OC in SLI
3x Maxtor DiamondMax10 300GB HDD in RAID-0
2x hp dvd740 DVD Writer optical drive | 1x Mitsumi FA404M 7-in-1 USB 2.0 card reader and floppy drive
Antec P180 case
Enermax EG851AX-VH 660W Power Supply
Samsung SyncMaster 213T 21" 1600x1200 LCD Monitor
I just bought the ScreenClean and it seems to have removed all the streaks from the previous cleaner. Not cheap, but it should last a long time.
Brian Elfert
I will third the Monster ScreenClean. I just used it today to clean all the laptops, projection televisions, plasmas and LCD monitors in my store. I use it at home on my plasma as well.
I use a razor blade to slice the dirt off my lcd's. Give it a try :D \
The ScreenClean is good too.
