I feel like a huge dolt right now, made a series of stupid mistakes today.
Bought a Corsair H50 to replace the stock cooler on my Phenom II. When I was removing the heatsink I felt a bit of resistance, but didn't think anything of it. But then I noticed it had pulled the processor out and it was stuck on there. I got it off and tried to re-insert the CPU - no dice. Some of the pins were bent.
So in a momentary lapse of judgement, I began using the lead of a mechanical pencil to adjust the bent pins. After coming to my senses I switched to a tiny flathead.
What I'm worried about now is if I've got dirty pins. I noticed a couple specks of lead on one or two of the pins, and I know I managed to touch a few spots with my fingers. So I wet the edge of a paper towel with alcohol and tried to gently clean between the areas I was handling.
I've gone over it with a magnifying glass and everything looks quite clean now. I can also fit it back in the socket again. But how sensitive are these things, really? From what I understand, you've got to worry about creating a connection between pins and causing a short-circuit. There's definitely nothing on there large enough to reach across pins like that.
