How safe is the coolbits auto detect optimal frequencies
does it artifact on you at those settings? try a program like atitool beta15. coolbits is usually pretty inaccurate. It used to be way too low. Now it's going way too high and the results it thinks are good actually artifact like crazy
I've found that I could sometimes go further than the detect button would recommend, but not often. I've never actually had a problem with the frequencies it recommended though.
Alright, just got done putting on my vf900. I should have done testing at stock voltages first, but I was curious how it would fair with overvoltage. Right now, gpu is sitting at around 1.49v as measured by dmm, and ram at about 2.19v once the graphite heats up. The sad thing is that ram still won't budge above 800mhz that I was able to get at stock voltage and heatsink (okok theyre hynix 1.4ns that're only rated for 714, but that's at 1.8v or 1.9v, not 2.2v!). Core was stable at 580 with stock cooler and stock volts, 650 with 1.4v and stock cooler, and 680 with 1.5v and stock cooler. Right now with 1.5v and zalman vf900, I'm seeing 700mhz to the core as the stable max. Kind of funny since I had set a goal of hitting 700, but was aspiring for more. Too bad the ram can't go any higher. I understand they run weaker timings too than the gtx bios sets forth (hence why our ram clocks higher on standard)
edit: grrr 700 core gives an occassional artifact. Oh well. guess it's back to 680/690 unless I'm tempted to try 1.55v. It's a shame 1.4v to 1.5v only netted 30mhz extra to the core, whereas 1.2v to 1.4v gained me 70. Oh wait, I guess that's pretty linear.
edit: looks like I jumped way too quickly to assumptions. I was testing 700core and then increasing ram, but forgot to check 700 for stability first. Now I'm back to 680 core but ram scales up to 880 at 2.19v. Guess it's livable ;-). Shouldn't get too greedy, seeing how stock is 450/660 and I'm up to 680/880 with a troublesome card from the start.
