hi i want to get water cooling but is i reliable because my comp is always on and im not always with it.
It's as reliable as A) the parts you buy (quality) and B) your abilities. You buy cheap crap or you don't do a good job and you're hosed. (no pun intended)
QFT
My water cooled Koolance Exos went for 4 years without a single drop of water entering the computer. Then one day I spilled a glass of water into it and it died.
Moral of story: Water can kill your computer if accidents happen. So don't water cool unless you keep the glasses of water away from your computer.![]()
Water is quiet, efficient and reliable when done properly. I was a noob, but Arcy came to my rescue and today I worship him as my master. It is really important you buy the right parts. A hint: D-Tek make awesome cpu blocks.
However, water cooling is extremely room temperature dependant. You tend to push your system more on water because you know all that cash and time you invested into it was worth it. However, yesterday, while I was at my mouse dissection lab, temp rose to around 36 outside during the day, it was about 35 inside (versus the usual 23) and I came back to a dead 680i ... last thing I saw was a frozen screen with TAT showing CPU @ 80C something...
I really don't regret I went with water, you will get the most out of your system if done properly... oh and get coolsleeves, they're sexy !![]()
The pump is probably where you want to start if you wanna to look more into reliability. It's the most important part of your loop.
water cooling can be very reliable, just get good components, test well, and use worm clamps around all tubing connections.
Oh the irony of it all![]()
That's exactly what I said after pissing and moaning about it for about a week.![]()
You probably just fried the control board in there.. they are like 20 bucks off the koolance website.. It would be worth the investment to see if you can revive it.
The EXOS works fine, but it was the MB that got splashed.
