How reliable are Epox boards???
rsnellma
I am thinking of buying an Epox board, but know nothing of them. I have always heard they are good, but what makes them so good. I have always been an Asus !!!!!!, but I am looking for a good, reliable, stable, dependable BUT cheap, cheaper than the big boys out there, like Asus, MSI, GigaByte, etc. I would like to limit it to NForce3 250Gb chipset, if the price is cheap enough...no more than $100 would be nice. Because I will need to get an AMD64 2800+, which NewEgg has for $128, right now.
My 2nd Rig in my sig is what I am looking at upgrading. I need to replace the Mobo & CPU for now.
Someone suggested the Epox EP-8KDA3J mobo. Does anyone have it and what has been your experience with it?
So, my list of motherboards that I am considering...
Asus K8N-E Deluxe - already have one so I know they are rock solid, but expensive...
ChainTech VNF3-250 - I have heard good things about it, but no 250Gb chipset...
DFI LanParty UT-250Gb - heard great things, but I don't overclock...
Epox EP-8KDA3J - heard of Epox, but am a little leary about the quality...
Prices on NewEgg
Asus K8N-E Deluxe $129.00
ChainTech VNF3-250 $78.99
DFI LanParty UT-250Gb $108.00
Epox EP-8KDA3J $71.99
While I am on the subject of Epox, can anyone tell me the differences between the EP-8KDA3J & EP-8kDA3+? The price difference is like $40.
Any help with Epox quality and reliablity would be greatly appreciated.
Thanks in advance.
Bob2001
The KDA 3+ comes with the epox power pack, essentialy a screwdriver, some case badges, heatsinks for the mosfets, and a little bag to put them all in. ie. not worth 40$.
My epox board is great, solid as anything, and i actually mean solid, i dropped my old thermaltake sl55, do i mean thermal take? maybe i mean thermalright, anyway the big ass copper thing, on the chipset heatsink and its still fine, lucky me.
I chose the Epox 9NDA3+ motherboard for my new system. I liked the motherboard layout (mostly) compared to the other boards out there except for the ATX power placement and the location of SATA 1 and 2, but neither one was a showstopper, just a mild inconvenience.
My board is running great and was easy to setup. I bought it based off of success with previous Epox boards I used for my brothers computers, the 8KHA+. (old VIA KT266 chipset) Both are still running 100%.
The 9NDA3J is just a stripped down version of the 9NDA3+. They took off the Firewire controller (who cares), the Marvell controller that ran 2 of the SATA ports (which isn't locked and unusable if you overclock anyway), and used a lesser Realtek audio chip (as if there's actually a good one). They also took out some of the goodies in the box like rounded IDE cables, 4-way screwdriver (actually useful), MOSFET heatsinks, and such.
The laminated fold-out diagram is an incredibly useful setup reference and something I wish more companies would include, especially if you have a case where the USB/Firewire connector wires are all seperated and you have to look up the pin-outs to hook them up correctly. This diagram makes it much easier to do and is in color.
I've also heard the J actually has better voltage options in the BIOS for the CPU, but obviously can't verify.
I haven't had a problem with Epox build quality and prefer it to several of the 1st Tier manufacturers like Abit and MSI because it seems like Epox tries harder to fix problems (if they have any).
EDIT: (Condensed version)
Epox build quality: fine, no problems, easy setup.
9NDA3+: Flagship 939pin nForce3 Ultra motherboard
9NDA3J: Entry level 939pin nForce3 Ultra motherboard (minus several features of flagship model, see above if interested)
Oh, thought I would mention that this upgrade will be used for light gaming, but mostly my home business, you know the usual of email, web research, downloads, etc. I need the older parts to upgrade a friends and thought I should just upgrade to 64bit processing, if I can do it on the cheap side.
Thanks again.
Bob2001
it's bad (and not good bad)
serious random reboot issues .no overclocking and it's a party to see if I can get into windows...safe mode doesn't help either.
Seriously undervolts too - my 3000+ winnie was at 1.34 actual I tried bumping just that becuase I thought it was it - at +.03 it does 1.55 actual..... nice huh? Still did not fixe the problems -
anandtech had similar issues with the + version in his review.
even running 02/15/05 bios - no luck....
the early rev kda3J's had serious undervolting problems...my rev 2.2 is stable...currently testing a mixed set of 1gb ram (KHX PC4000 and buffalo PC3700), stable so far in slots 1/3. if you're looking for oc'ability, stay away from this mobo. i've always had good experiences w/epox (8RDA+ rev 1 and 1.1, 8KRA2+ and 8RDA3+ rev 3.2) but i know lately some people haven't been very happy with epox...personally, i would go with msi or dfi (which is what i'll do w/ my 939 upgrade)...
Love Epox, got some of my personal best overclocks on Epox boards...sadly they have been really late to market with some of the newer boards. But as much as i think their boards kick ass (incredible BIOS options), the support leaves much to be desired...as they are not particularly big here in the states
Not a big Epox fan here. I've had a couple of their Socket A boards, and they were both nighmares to work with. Now, I did have a flawless time with an MVP3G2, but that was an old Socket 7 board. I just can't accept a motherboard company who's products fail after a couple weeks and/or don't work with any other RAM I have which works fine in everything else I own.
And, yeah, Epox isn't exactly the first one out the door with things either.
sorry, but 2.8Vdimm is NOT incredible...that kind of limit should be on an ECS or ASRock...
