How quiet is this computer?
The 8800GTX is definety quiet, I can barely hear mine when the fan is going. But, the way to have a quiet system is to get quiet fans for your case. This includes the CPU heatsink fan, and all of your case fans. Other than that, the only noise you should hear is from your hard drives or optical drives when you insert a disk.
what is a good heatsink for the cpu and case fans for the case i am getting than?
In the P180, the Scythe Ninja is nearly perfect. A tiny bit of ducting, and you won't even need a fan on the heatsink.
u sure i wont need a fan?
the cpu i am getting is top of the line one and that won't require more cooling or anything?
the heatsink says it can attach a 120mm fan.
