How much will you pay for a 30" LCD?
How much are you willing to spend on a 30" LCD?
  • $2000 to $2500
    Votes: 13 19.4%
  • $2501 to $3000
    Votes: 1 1.5%
  • $3001 to $3500
    Votes: 3 4.5%
  • Wait for the price to come down to the $1500 to $2000 range
    Votes: 50 74.6%
  • Total voters
    67
Happy Hopping
Knowing Apple's 30" LCD is from LG-Philips, other OEM manufacturer will come up w/ their ver. of 30" LCD. Expecting it soon (worst case before Christmas). When it's available, how much are you willing to spend for a 30" LCD panel, 2560 x 1600 res., at 16 ms, high contrast ratio?
I chat w/ HP today, they said that for a LCD of that size, Quadro is the only option, or the ATI equiva. They strongly suggest that 30" is meant to use as a prof. workstation, and only high end video card like quadro can work well w/ it.
I have use the Quadro driver on some games. In some ways, they are better, in some other ways, it is not working. For e.g.,
running an old game Monopoly gives a smooth spotlight on the token in which it doesn't work on the Nvidia driver. However, the background is supposedly to be flooded w/ the brown color $$$ sign, but all I get is green square.
yes, a monitor that big will probably require a dual-link dvi -- only found in very high-end cards. ($500+)
The Quadro Driver won´t help, because you don´t get a second TMDS Transmitter by this tweak. To drive a 2560x1600 TFT@DVI you will have to buy a real QuadroFX with Dual-Link DVI (e.g. 3000/4000/3400).
Denis
Prob pay around $2000 for one. I got my 23" for $1500. So $500 is okay for 7" more....
From LG its not yet available for sale but it was on display connected to a
media Center gateway. And At least 3 persons would have bought it that day if it had been available for sale.
$3999. Thats the price on it. It has like a bazillion connections.
Dvi,Composite,audio/Av out/in,Vga. I mean its stacked to the gills.
And its drop dead gorgeous. This was on a Radeon x600. And it looked fine.
@ReubenRosa: The video-card you mentioned doesn´t have Dual-Link DVI. So there are two possibilities: The Display you´ve seen didn´t have a resolution of 2560x1600 or was driven at an extrem low refresh rate (but I don´t believe this). The Apple 30" drives the 2560x1600@~50Hz with DualLink (330MHz bandwith) DVI.
Any other >1920x1200 TFT will need Dual-Link DVI as input too, regardless from which manufacturer it was build.
Denis
I wasn't suggesting the LG is better then the Apple. I would never suggest tthat from what I know the max res of the LG is nothing compared to the Apple. 1280x960. But that customers didn't give a rats butt about that..
The quality was good enough that they would still pay 4grand for it.
of course if I had that much moola to throw around. Sigh. :(
I believe the new Apple 30" USE panels from LG. So the other LCD you see has a panel from somewhere else or it has old panels.
son of a :eek: . that sux that the resolution's better on the other one.
i think i'd just "make do" with a 22" CRT till the price came down to what i think is reasonable (comparable to the directron one)
On the eve of getting a Quadro FX 3400, I can't wait for a 30" LCD option. The only displays (LCD and CRT) that I have come across that can support the sick resolutions that the FX 3400 boasts are the T221DG5 and the VP2290b. Both of these displays accomodate dual-link DVI in order to get to those higher resolutions but they are uber expensive.
Has anyone come across any CRT monitors that can display these ultra-high resolutions? I'm not 100% sure, but I thought I saw a 50ms response time on the VP2290b.
Does anyone know what the response time and refresh rate @ native resolution is on the apple 30"?
Still looking for the happy medium between ultra high res, low response and high refresh in a CRT or DFP.
This high resolution only makes sense on a TFT@DVI. The dot pitch even of the best CRTs (i had the FW-900 before) isn´t fine enough. Another factor is the D/A conversion.
The FX3400 is a good choice for the 30" cinema. I will go this way too but don´t expect the Apple here before end of november :-(
Denis
P.S. The Apple 30" TFT will run at about 50Hz if I calculated right.
Cool, thanks for the insight.
I too am eager to see more specs on the apple, as well as what the other manufacturers will follow suit with.
I hope the connectivity is better than on the apple and sony 23" bad boys.
I have my eye on the FX3400 too. But FX3400 doesn't do native at 2560x1600. There is a gap from the res. below and above. What's the best way to solve this issue?
No problem, there is no not supported lower resolution. The nVidia driver allows you to define custom resolutions. If that wouldn´t work you could use Powerstrip as well.
But I think it should go "out of the box" through the DDC information of the TFT.
Denis
Judging by the number of votes for each price range it looks like we have 9 people who bought the Samsung 24", 33 Apple/Sony/HP purchasers of their 23" or less and the other 3 are rich people who care less about money. :cool:
Yah, Tom Cruise logon the other day. :D
Sailor Moon, what's DDC?
:p don't forget the lone geek who's gonna wait it out till it hits the current price of a 22" crt monitor... that geek would be me.
:rolleyes: like it'll ever get *that* cheap
/heavy sigh
If you waited that long, by then, there will be 40" LCD and the cycle repeats again.
I don't see any real reason to need that much resolution. 1600x1200 on my 2001FP is fine for me... for widescreen I still wouldn't need more than 1200 lines of resolution. It's almost as good to get a HDTV LCD that would do 1080p.
But to answer the question, I'd expect to pay about $2000
well, I'm using 16 x 12, it is too small, and not enough spc. for me. 2560x1600 is what I really needed, preferably more. More is better.
Out of curiousity, would having a multiple monitor be a possibility for you, Happy Hopping? The fact is, you could have multiple video cards running multiple smaller monitors but you would need one very fast, very expensive video card to run a single monitor at the resolution you're desiring. If you're the type that has multiple windows for multiple applications open and you don't need to see everything at once, that might be an option for you. This also lets you game with reasonable framerates on one of your monitors without sacrificing image quality due to scaling up to 2560x1600 on a single monitor. Higher end of the midrange vid cards run games on the 23 inch wide screens just fine, for instance. I shudder to think of the framerates you'd be getting at 2560x1600, while playing at a lower resolution at nonnative resolution seems like such a waste...
Even with a 23 inch monitor I find it annoying that I have IE maximized most of the time and I'm alt tabbing through various applications the same way I do with my 1024x768 laptop screen - feels like I'm wasting the wide screen high res features of my monitor. The reason I have it maximized because popups mess up my "default" window settings after I close them because Windows doesn't seem to get that I want to keep my non-maximized windows a certain size. On a similar note, I'd really like a way to permanently set window sizes/positions in WinXP that aren't overwritten every time I move/resize a window and then close it. Any ideas? Maybe Hydravision has something, I guess I'll have to check again.
No 2+ monitor is not perfect. And my max. desk available is around 30" diagonal space available. I can't stand having a "bar" in btwn. 2 monitor viewing some application or a game.
I could make some more space available on my desk, as I have 2 desks (an L shape desk), but I prefer 1 big monitor instead. I rather spend the money on a FX3400 than buying 2 monitor w/ a dual output video card.
Right, but even with the best video card I don't think any games support that resolution just yet. So you're still going to have scaling issues. And even if the software did support it, we're talking at least 113.33% more pixels than on a 1600x1200 which means frame rates of not even half of what you're seeing on a 1600x1200. Maybe a better route to go if you're thinking about gaming in 2560x1600 is SLI :D - does the FX3400 do that?
If you're not going to be doing PC gaming then that'd be great I think - definitely beats a multiple monitor set up. But if you're a serious gamer I'd consider getting something with smaller resolution in the mean time till videocards and software catch up with monitor technology.
Are you familiar with dual monitors? You don't have bars in between applications unless you move the app to that spot. If you maximize an app, it maximize on its current monitor. I've run both dual 1600x1200 and dual 1920x1200 now and there's no good reason to maximize an app across both monitors, really. Actually for some applications it won't work, like Windows Media Player - only the half of the video on the primary monitor will be displayed, the other half is left blank I think. But again, maximizing that in one screen is plenty. Anyhow, I understand that not everyone is a fan of dual monitors - I myself no longer am - but I'm just making sure you understand the technology before you totally write it off...
Of course you won´t be able to play new games in the native resolution. But this is (or will be soon) a problem of the 1920x1200 panels too, at least if you turn on quality features like AA or AF.
But 2560x1600 => 1280x800 is a nice resolution for this panel. Exactly 1/4 of the native resolution, scaling will look nice.
Denis
I actually don't do as much gaming as I use to be. The screen is used for business use during the day, and whatever game I like in the late afternoon if I have time and in the weekend only.
When I said bar, I mean the actual plastic frame of the monitors, if you display a game or application across, the plastic frame is a bar that gaps the eyesight.
"When I said bar, I mean the actual plastic frame of the monitors, if you display a game or application across, the plastic frame is a bar that gaps the eyesight."
Hmm, right, I'm just making sure that you understand that when you do that with a multi monitor set up, by default the application will only maximize on the current screen and not across all of them... ie you're not forced to span your application across multiple monitors although that option is available in some instances...
Denis, hmm, I wasn't aware that 1280x800 was a standard resolution offered on many modern games... actually I just checked UT2K4 and it does offer 1280x800 resolution. So I stand corrected, you should be able to game on that after all =) As a side note, I'm surprised UT2K4 doesn't offer 1280x720 as well?
This resolution should be no problem with most games. They usually don´t offer it via game menue. But in most cases you can edit the config files of the game (for example: Q3A Engine, Doom3, UT2003/04 etc.) and change the FOV too (because most games have a fixed aspect ratio, so just switching to a widescreen resolution doesn´t help).
The resolution must be available in windows, with nVidia there´s no problem, you can create custom resolutions; Powerstrip is also a solution.
http://www.widescreengamingforum.com/phpBB2/
Denis
