I tested my pump for the first time now this week. And the pump is vibrating alot, i know it is supposed to but how much should it vibrate?? If i just let it stand on the table it sounds like 40dB from the pump hitting the table. It have ran for 24 hour and there is no air in the system I only have the tank in the loop at the moment. Exept for the vibrating it is soundless I have to put my ear closer than 40cm to hear it in a real silent room.
Any tips on how to mount this thing to remove the vibration. Will these bubble plastic thingy you get in packets do the trick?
The pump is a eheim 1046 I'm aiming on death silent just so you know.
EDIT: Is the pump water cooled??
