How much Vcore can the Conroes take?
-iLLuZioN-B18C1
does it matter how much voltage is given to these cpus? cause at 1.425V the temps are still low. idling is 45C and dual core priming is 54-57C both in Core Temp. or basically can i just up the voltage until it reaches a threshold on temp?
Im sure others will chime in but at some point the voltage will start to cause problems regardless of temps. I may be wrong on this but I wouldn't push one for any extended amount of time beyond 1.4v myself.
Well, 1.4V seems to be what I'm seeing, but we also don't know if these Conroes have another nasty SNDS bug in them. I wouldn't risk it.
My gigabyte dq6 puts my E6600 running @ 3ghz and 1.45v .. no problems at all
i have a ds3 w/ e6400 and up until last night i was still using the f4c bios at 1.325 vcore stable at 2920mhz. uping the vcore made no difference.
i updated to f7 bios and seems to be better as i was able to bump vcore to 1.425 and 3160mhz.
my house thermostat says 66F so its about 20C. my cpu idles at 24C right now.
temperature getting colder out is helping so much. back in summer my cpu was idling at 36C. so even after bumping the vcore the temp seems reallly low still.
My E6600 and DS3 Mobo is *almost* stable at 3.2Ghz on stock VCore. How close I was! How happy I would have been! Is F7 more stable for overclocks then F6, because that is what I am using right now - maybe if I keep stressing it at 3.2Ghz even though it might keep failing, I'll get a burn-in like effect and it will become stable at that speed.
Failed 4 hours and 15 minutes into the Go-Orthos Stress Test :( (8 hours I consider 100% if I drop the speed by 50Mhz) - 3.2 on stock VCore would have been so amazing! :(
I may try 1.35V later, or I'll do a 450x7 combination instead of 400x8, but then that will require me to find good RAM voltage + stable timings at 900Mhz. I to would not risk going above a 1.4V Vcore, though people do have them pushed up to 1.6V (watercooled).
I don't know though, right now I'm running 2.88Ghz (320x9) with the ram at 4:5 which is fine... but overclocking is addicting.
I think the general consensus is 1.5 on good quality air and 1.6 on water. 1.4 is more or less factory voltage,I guess some people are into the undervolting thing though.
