How much to O/C?
vegetash
I have an Athlon XP 1700 and it is running at about 41C with a case temp of upper 20C's. I see that theres two ways to overclock; changing the FSB and changing the multiplier. How much do you think I can O/C with temperatures likle that? and which method is better?
Alittle more information would help a bit. What type of memory are you using. Though with those temps you may be able to up your 1700 quite a bit. There a few ways you can go about OC'in. One would be to lower the multi and raise your FSB. It really just depends on what type of memory you are running so you can tell how far you can push it.
hmm, i dont think my memory is very good, i didnt pay that much for it, im trying to remember what i got, Dana-Elec rings a bell, ya i dont think thats very good :(
If you are able to change the mulipliers in your bios I'd say just do that. Your FSB won't go much higher then 133 , maybe 138 if you are lucky. I'd say try changing the multiplier and leave your memory as is for now.
Good luck on the oc those 1700's are sexy :D
i just read about some guy who go his 1700 running at 2300 speeds! is that like with hardcore cooling only? if I O/Ced to much, will the mobo tell me? cause i notice one of the debug messages on my epox 8kha+ said "overclcok fail"
Ok, I got some conductive nickel paint at my local electronics shop (the guy even said "what are you gonna do with it overclock?" that was pretty cool :p) and well I found that my mobo supports multipliers up to 15!!! I want to get close to 2 gighz out of my 1700XP, is this possible? based on my current temps and speed it seems that at a 400 mhz overclock the temps will still be ok:
1470/42(current temp under current speed)
1470/42 = 1870/x
x = 58C
is this accurate or do temps go up exponentially as i overclock? I see that athlon xp pallys can go up to 90C before a burnout and this is well under that.
also:
http://www.cpuheat.wz.cz/html/Tweaks.htm
whats this?
