Ciggarilo Himself
- Nov 22, 2006
How much ram are you using with vista rigs?and how is it running(slow,fast,choppy ect)
Thanks.
Thanks.
∞Velocitymaster∞;1030577489 said:all sounds good but I want to use dual chanel
Do you sell ram for a living? My PC does excellent with 2 gigThe basic rule of thumb for Vista and RAM probably would look like this:
Under 1GB = RUN and get more.
1GB = Works fine, but gets winded near the end of the run.
1.5GB = Much better, not as winded, room to breathe.
2GB = The sweet spot, but not quite the runner's high.
2GB+ = Now you're getting there, almost like floating...
4GB = Home sweet home in the clouds.
A lot of that is stuff that could be swapped out when the system is under memory pressure. So, despite that measurement, the extra 2 GB may not help you much in terms of actual measured performance in games and apps. OTOH, 4 GB does seem like a good lifestyle choice, doesn't it?? I have to admit I'm tempted to get 4 GB, although I know full well that at least 2 GB would be wasted most of the time (maybe get some benefit from a bigger FS cache...).Im running a Logictech G15 gammer keyboard that shows ram usage in an LED window. When I was at 2gig in XP the ram usage was usually around 20%. Then I went dual boot (separate Xraptors raid0) Vista Ultimate and ram usage was usually 50%. This is with the system static, not under load. That's why I went to 4 gigs. It seems better for Vista.
