DeChache
- Oct 30, 2005
I want to build an untangle box for use at home. The problem I am having is deciding how much hardware I need to throw at it. I have it narrowed down to two options basically.
1) Intel Atom 510 with 2 gig of ram.
2) Intel Mini-ITX i3 system. 2 gigs of ram.
Both systems will be using a dual port Intel Server Nic for network access.
There will be around 10 systems behind the file of which maybe 3-4 will be active at one time. Mainly just basic home internet usage from my 2 roommates and some gaming and other dutys with my systems though nothing heavy think WHS remote access and some RDP.
What system would you guys use. The only real requirements on my side is stability and low power usage. If the atom won't keep up I have no problem using the more powerful system but if the atom will do it. I would like to use that.
Thanks for the insight.
