How much noise do video cards make?
Vandillo
I’ve been reading that some people are having issues with fan noise on their graphics cards. Additionally, some are blaming Vista driver issues causing their fans to run continuously regardless of whether or not playing games (also even when turning off Aero effects). I’m looking at trying to get quiet pc running Vista and to that end I see that Asus makes a silent 7600GT incorporating passive heat sinks.
http://www.asus.com/products4.aspx?l1=2&l2=6&l3=0&model=1097&modelmenu=1
Has anyone used this card, if so do you like it, does it make a significant noise difference, and is it worth the extra $47 from the same model with a fan?
My gpu fan is the loudest thing in my system and only when gaming, watching videos. Otherwise the thing is quieter than my HD which is an old WD that is on its last legs. Sounds like a hair dryer a couple of rooms away is best as I can describe it. I don't know much about watercooling but how hard would it be to setup a small system for just the gpu?
