I have noticed Window 7 is really good at managing ram comparing to Vista. I have 8 GB of ram in one of my pc and I have noticed it's hardly ever used more than 3GB. As for Vista, I have 9GB of ram at work and it always go around 7 or 8 GB all the time. I didn't want to install Window 7 at work because of how many softwares I have to re-installed and not to mention about the settings I have on there.
If you are running Windows 7 32 bit you will "need" 2 GB of ram @ least.
If you are running Windows 7 64 bit you will "need" 4 GB of ram @ least.
I had 8Gig and I never used more than 2gig per system memory monitor. I scaled back to 4Gig and never noticed any performance hit. So, I say 4Gig is a good number.
Standard user: 2-3GB (lean towards 3)
Gamer: 4GB
Power User: 8GB
There is no reason not to be running 64-bit Win7 except on the off chance you're using a first-gen Atom or an ancient computer.
using windows vista/7 with 2 GBs of memory is a less than optimal experience.....for XP 2 was enough
