How much Hydrx is too much?
Flexion
I just installed a Swiftech Apex Ultra kit and it performs extremely well. However, coming out of a Thermaltake Bigwater that was probably junked by too much algae (just within 5 months), I want to make sure I get enough Hydrx in the system.
Swiftech recommends 10% for systems that are constantly exposed to light, but anyone have experience with putting too much coolant? I know Coolant makes the liquid more viscious.
I'd like to get some opinions.
Thanks.
you only need 10%, the more anitfireeze/hydrx/additve you add the hotter everything will run cause that stuff dont conduct heat as good as water
