How much $$ for this hardware?
pixelbaker
How much would you pay for the following hardware right now if it were offered to you as a bundle. I just made this purchased this set and I'm not sure on how good a deal I actually got.
MSI KT6v-LSR motherboard
-SATA150, IDE, onboard LAN/sound, for AMD Athlon XP/duron procs
AMD Athlon XP 2500+ Barton
Rosewill 512mb PC3200 DDR
XFX GeForce FX 5200 256mb
ATi Radeon 7000
What price for each component and then maybe a total if bought as a bundle?
Probably no more than $650, also is that two video cards you purchased?
EDIT: Okay I re bidded my price from $650 to say about $175
yes, two different video cards. you're sure about that $650 price. it's not a full system, just those components listed. that price seems a little high. I looked up the parts and brand new they were listing at around $300 total. I was wondering what you might actually pay for the hardware after being used a little and it's actual value now
it all works completely.
two vid cards because that's what the guy had that he wanted to get rid of. I can find some way to use them both
I'd like to get something like that for christmas...I like putting together second rigs, finding uses for things. Come to think of it, I could use something to host some files on and surf the internet...should ask for some cheap stuff hardware for christmas.
