I got a new Case to put all my stuff in to. It's an NZXT Trinity case that I got from Newegg.. I noticed that when I installed the mobo (ATX), that when screwing it all in, that it wasn't laying completely flat (yes, I used the brass spacers) and as I tightened down the screws, there was a bit of flex necessary in order to tighten it. Is a little bit of flex normal? I would say that it was about 1/8" gap that the mobo needed to flex for . (if that makes sense).
It seems like the plastic on the backside of the mobo under the cpu extends out a little further than what the brass spacers accomodate, causing it to "high center" against the case... not sure.
