xFuryofFivex said:isnt that essentially 2 7900GTX
jacuzz1 said:IT is clocked slower but has two cores. I suspect it will come in faster by about 20% and slower than two 7900GTX in sli. It will realy excell in games where 1 gig of frame buffer will give it a real advantage (none exist at the moment)
If the would release them sli ready , i would step up in a heart beat since they will retail about the same as a Super Clock.
LittleMe said:It doesn't have 1 gig of memory total. There is 1gig on "the card"(NV is calling it a single card since it only has 1 PCI-E connector) but it's really only 512MB per a core and it's not shared.
J-Mag said:
how so? the 7900GTX is the base 1.0score, and the highest one of the GX2 puts it at 1.8DusterAZ said:Arggg ... those graph scales are nuts Makes it look like it performs more than twice as fast as a single GTX.
Manoj said:All I can tell you guys that it will be a hard launch.
I got a call from a distributor that stock is on hand and I could get one now but need to keep quiet due to NDA. The launch will be in a couple of days time.
He said makes it look like, lol.lithium726 said:how so? the 7900GTX is the base 1.0score, and the highest one of the GX2 puts it at 1.8
jacuzz1 said:It in fact is shared as in it uses both sets of 512 on this device from what i have been told. That is the real advantage over normal sli cards. With quad their will only be 1 gig as opposed to 2 gig just like anyother sli setup
Think about it for a moment. There would be absolutely no reason to have one gig on the dual card otherwis
Each chip addresses 512MB of memory, meaning that each card has 1024MB memory or that Quad SLI totally features 2GB of graphic memory.
InternalStorm said:It is only about 20%-35% faster on average. The graph is VERY misleading, as the 7900GTX ends at a base score of 1.0, but goes down to 0.6. So really, 1.2 for the 7950GX2 is only a 20% increase in performance, and 1.6 would be 60%
Manoj said:That doesn't sound too bad right?
Nforce 590 SLI motherboards are optimized for Geforce 7900 GTX and Geforce 7950GX2.
vanilla_guerilla said:the 590 boards will shift resources (memory?voltage?) to the gtx cards as they need them while gaming or whatever. but only the gtx/gx/gx2, not gt. so far.
chinesepiratefood said:link boost is for any PCIe device, it is supposed to "boost" the transfer speed between the chipset and vid card
LittleMe said:It doesn't work for any PCIe device. This should help a little more.
http://www.nvidia.com/content/nforce5/TB-02423-001_v01_LinkBoost.pdf
Manoj said:Currently only Geforce 7900 GTX and Geforce 7950GX2 will support it.
LittleMe said:Yes, I know. I didn't make reference to it working with anything else just providing more information that it doesn't boost any and all PCIe devices. At any rate, even with 7950GX2's, I doubt it will do anything to improve performance since so far, it's only been shown make any effect at lower resolutions. And if you have 7900GTX's or above, why would you be gaming in something under 1280x1024.
