How Much Do You REALLY Need For Strictly Gaming?
Hello.
I am looking at building a PC strictly for the purpose of VR and gaming. VR will be the first thing I use this for but I would like to be in the FreeSync/G-Sync frame rate range(~75-100Hz) of 3440x1440 monitors, with high-ish settings, in case I win the damn lottery someday. That and I don't want to puke my guts out because of dropped frames in VR. I don't want to overspend on the CPU and RAM, or anything else for that matter. For the GPU I am looking at a GTX 1070 or 1080. I really want to go with a locked i5 7xxx or even an i3 8xxx with 8 GB of RAM. Won't this be sufficient for just gaming, especially at higher resolutions where the workload is mostly GPU dependent, or am I a disillusioned maniac? I just want to game at modern resolutions on modern hardware. I wont be running Cinebench, firestrike, or ePeen 5000 and if I ever do I will upgrade, or more likely just shoot myself. I am looking solely for game and VR competency.
If my GPU selections are overkill, please let me know.
I have a build list but want to make sure I'm not crazy.
Thanks!
I think this is sensible. Games don't look like they'll efficiently utilize more than 4 cores for years. I think a locked 6-core i5 would be a great pairing for a GTX 1070 or 1080. 8 GB of RAM won't feel restrictive until you play on something like PUBG. Unoptimized higher end games can be a pain if you don't have 12-16 GB of RAM. (I mention 12 as I run a 3x4GB in my tri-channel x58 system)
It's a totally subjective question.
What one person thinks looks fantastic, another will think runs like crap.
It's all about setting a reasonable budget, and then building the best you can within that budget. That number will vary a lot from person to person.
I have been following some tech channels and looking through forums. Especially certain TechTubers that cater to mostly gamer audiences seem to feature $2500+ builds that many people would never come close to fully utilizing. For the PC I am looking to build, I would like to stay near the $1000 mark for the hardware, not counting the VR components. I am seeing this is a bit of a challenge but I can get close. Right now the biggest cost variables appear to lie with CPU and Ram selection. I would also like to be able to get away with a cheaper 8GB RX 580. My current machine is running an i7 3770, 16GB of 1866, and an RX 470 4Gb and it rocks at 1080p gaming with higher settings, but it is really more of a work machine. I have wanted to get into VR for a long time and am hoping to build a reasonably priced machine for only that purpose.
If you want to games with a 3440x1440 and utilize your 75-100hz on any game, you have no choice but to go for a 1080 ti in my opinion.
A 580 isn't going to run 1440p on high quality for most games, unless you're willing to settle for lower fps.
