How much coolant?
Shadowspawn
I am building a case mod and integrating my first watercooling setup...while I'm here in Iraq. This makes purchasing a bit more difficult because I can't just run down to the store.
I am looking at purchasing coolant (MCT-5 Non-Conductive Solution) and need to figure out how much. The bottles are 32oz.
The system is a M-ATX with a single 8800GTS, X2 4400, T-line and dual 80mm radiator. There will not be a tank.
How many bottles will I need, roughly?
astyler
Just 1, but I'd get 2 so you have extra on hand if you drain/refill. My loop has 2 rads, micro-res, gpu, cpu, pump, and nb block, and I probably use around a 1/4 gallon (32 oz.) when I fill it (7/16" inner dia. @ 6ft. of tubing)
