How much can I OC?
murilo305
How much can I OC?
CPU: 2.33Ghz Intel Core 2 Duo E6550 4MB Cache FSB 1333
Cooling:Cooler Master Aquagate S1 RL-EUL-GBU1-GP 120mm Liquid Cooling System
PSU:400watt Stock Supply included with case
Motherbored:EVGA 122-CK-NF66-T1 (nForce 650i SLI, PCIEx, 8-Channel Audio, LAN, 4xSATA2, 4xDDR2, 1394, 1333FSB)
Ram: 1g
Each OC is unique... Only you can know once you try, and we cant help you at all without telling us more about your ram.
It depends.. you havnt told me the ram speed for a start..
you should be able to get 3ghz at least.
That processor has a 7x multiplier. With DDR2-800 ram and the FSB at 400 you would get 2.8ghz out of it. To go higher you would need faster RAM and I don't know the limits of the FSB on that board.
