How much can I OC my current system
Owskie
Its a bit old, but I bought it knowing that I could OC at somepoint and never did...
AMD Athlon 1.8ghz
Abit NF7-S 2.0 Mobo / 333 fsb Barton Core.
ATI Radeon 9800 pro
1 Gig of Ram (dual corsair 512's)
check my sig. You can probably get around that with the quality of your build
With a Speeze 7 cooler(are they even available anymore.. then again, there is a lot better stuff out there), it should run fine at 2.2Ghz.... if it is a good chip, it should even do that at stock voltage.
As for how far it will overclock.. maybe 2.4 if you push it.
I had my 3200+ (stock 2.2Ghz) running at 2.6Ghz.
If you have DDR400 RAM.. just bump the bus speed to 400 from 333 and see if it works.. that will give you 2.2Ghz which the last couple chips I have tried would do easily.
If not... change the RAM/CPU divider so the RAM will still be running at DDR333 first. Thew 5/6 divider should do the trick just fine.
