How much bigger % is 2407 vs 2007?
plasma
Does anyone know how to figure out roughly how much more real estate the 2407 has vs the 2007? or even just 20 or 21" vs 24"?
Eagle156 said:
24-20= 4
4/24=.1666666 %16 larger area, simple 8th grade math. ;)
Yep you're right, except it is not 16% larger area, it is 16% longer diagonally.
2007: 17 inches by 10.7 inches = 181.9 square inches of area
2407: 20.4 inches by 12.7 inches = 259.08 square inches of area
Percent more area = ((259.08 - 181.9)/181.9) * 100
Therefore, the 2407 has 42.4% more screen real estate than the 2007.
Thank you Ohji :)
I know how to do simple 8th grade math:rolleyes: to find the percentage, but I knew it wasnt a simple 4" difference. I didnt know the exact screen dimensions to figure out the surface area to compare in the first place. thanks :)
plasma said:
Thank you Ohji :)
With 8th grade math you should be able to calculate it.
Think of it as a right triangle with the 24" dimension being your hypotenuse. Since its a 16:10 aspect ratio display, its dimensions will be some multiple of any other 16:10 display.
We can calculate the length of the hypotenuse of a 16"x10" display using our friend the pythagorean theorem which comes out to approx 18.87". This means that the dimensions of our 24" display is around 24/18.87 = 1.27 times what a 16"x10" one would be.
Width 16"x1.27 = 20.32" and Height 10"x1.27 = 12.7" so the area for our 24" display is 20.32"x12.7" = 258sqin.
(note: if you don't round off the calculations throughout, the numbers match what tv calculator gives. in all cases the dimensions are slightly off from the listed panel specs.)
I'm not insulting yer math abilities but I'm bored and the vista download is taking forever, besides this is part of the "How" to your original question aside from consulting the documentation. :D
Are you talking about physical screen area or resolution? cause some notebook 15" displays have 1920x1200 resolution....
The math is much less complicated even.
The area of the screen is proportional to the square of the diagonal.
Therefore the ratio in area is (24/20)^2 = 1.44 => 144% (assuming both have the same aspect ratio, which they do).
