I always just use about a pea sized amount. Make sure you put it on the processor and then squeeze the heatsink/fan onto it. That way you get less air bubbles![]()
peas?
i recall reading a grain of rice size, or a bb size.
either way the stuff owns
Between the E6600 and it's stock heatsink?
99%? lolClean the shit out of both surfaces with ArticClean or 99% Isopropyl alcohol.
IIRC, the reason you want to go with the "pea size drop in the middle of the IHS" is because if you go with any other method, such as an X shape, or speading the goop manually, it will surly cause air bubbles. Putting it in the middle of the IHS, plopping down the HSF ontop and giving it a little twist back and forth seem to work the best. And DONT lift the HSF off the CPU to look how good of a job it did, cuz thats going to cause horrendous air bubbles.
99%? lol
Overkill much?
91% should work just fine and you can actually easily find the stuff.
rofflecakes, i think i'm going to need alot more AS5
