I've been reading about the significant quick disconnect pressure drop. The Koolance QD3 series causes about 0.7 psi pressure drop from a single set at 4L/min, and I imagine that scales for multiple sets. The D5 pump can handle about 5 psi pressure at 1 gallon/min from what I've read. I was planning on getting three quick disconnects, one before the cpu, one between cpu and gpu block, and one after the gpu. Now I'm thinking that I should only get two to minimize restriction.
My setup has dual D5 pumps in series which should double the psi my system can handle. My restriction in the system will come from 3 radiators, the cpu block, 2 or 3 quick disconnects, and a EK quad semi-parallel block.
