how many problems have you run into with your comp?
stpstrn
building my first piece parts comp over break. how many problems should i expect to run into. my dad is the one helping me, who knows comps very well. when i leave back for school it will be my only comp so i have to get it right the first time and hope everything works well
There is a certain rate of failure on new parts, expect at least one part to be bad and have to RMA it, if you are lucky enough not to have to, great!
how much trouble with my current PC have I had? I got it all new almolst 2 years ago now, and then added used SCSI array later. the video card has errors, and I never bothered to RMA it until now, im going to in a week or so, already got the number. the SCSI drives, were refurbs, and were used after refurbd, Lets just say I got 10 SCSI paperweights for my trouble. I am never buying a used drive again. ever.
But as far as trouble, other then the vidcard having little black specks in 3D which I just put up with, the system has always been 100% stable and rock solid, and just crashed for THE FIRST TIME on me EVER last night o_O that was quite a surprise...
anyways, if you choose good parts and are ready to RMA a part or two, you should be fine. make sure you choose parts carefully including the power supply. Ive been a tech for well over 10 years and for a bit over a year in 2001 was the head tech of a computer store, I saw a lot of wierd and horrid comp hardware failures believe me. a lot less from quality parts, but the people bringing systems in didnt get quality, of course...
Out of box DOA's aren't quite as rare as I'd like them to be, but it's certanly the exception rather than the rule; out of the last, say fifteen systems I've built, I think I've returned one motherboard.
A slightly bigger problem is "infant mortality"; that is, parts / cards that work fine on first power up, but fail within the first 72 hours or so of operation. Only way to get past this is to turn the system on and let it run for a few days nonstop, so that you can hopefully find any remaining issues you may have.
All things considered, most hardware is more reliable than ever....my guess is that things will go just fine.
Regards - B.B.S.
I think that saying you should expect something to go wrong is quite jaded. I've built around 10-15 systems in that last few years and the only thing that ever went wrong was a bad keyboard, and that was a hand-me-down.
Don't fret, do everything carefully and you should be good to go.
Expect the worst and when it doesn't happen you will be quite happy...
The worst I've had in 5 years is a bad stick of RAM and a bad HDD. :D
I would expect that drivers are as big of a problem as actual faults with the hardware. If you're aware of the driver issues that can crop up and are prepared for them (already burned them to a CD, or know which ones you need to get), then it'll make life much simpler. I know that when building my sigged rig, drivers just about, well, drove me up the wall. The hardware came in without any troubles whatsoever. Being my first build and having bought bleeding edge (at the time), it took me a good while to get it all ironed out. Once done, though, no real troubles until I "upgraded" to a 9800 Pro. Now I get to figure that one out. Yay
