How many monitors does it supoort?
STRESSTEST
I have the EVGA 02G-P4-2678-KR GTX 670 card. There are 2 DVI, 1 HDMI and 1 display port.
Anyone know how many monitors this card can run at once? I only have VGA/DVI monitors right now so I cant test if it will run monitors off of the other two heads. But that is the plan.
tia
Four. Three in Surround, one as an accessory display. I'm not sure if you have to link three displays together in order to enable the fourth, or if they can all be run independently.
I was running this setup earlier. I have 3 Samsung T260s in surround plus a Compaq Q1859 as accessory all hooked up to the four ports on the card. If you are NOT running them in surround, I believe it can be a combination of any 4 monitors. But for surround, you need the three in surround to be the same. If it helps, this is how I had them hooked up,
Display port(670) -> dp to dvi adapter -> dvi to dvi cable -> dvi (T260)
HDMI(670) -> hdmi to hdmi cable -> hdmi (T260)
DVI(670) -> dvi to dvi cable -> dvi (T260)
DVI(670) -> dvi to vga adapter -> vga to vga cable -> vga (Q1859)
I had the T260s in surround and then extended that "single display" to the compaq for accessory.
