Cooling System
- Rear: 2 x 92mm intake fans, 2100rpm, 23dBA
- Side: 2 x 120mm HDD intake fans, 1200rpm, 21dBA
- Top: 2 x 120mm exhaust fan, 1200rpm, 21dBA
Newegg product description.
I thought there were more because people were putting quad rad's in theres?
It officially only supports 2 92mm fans in the back, 2 120mm fans up top, and 2 120mm fans in the basement (attached to hdd cages).
That said, you can remove the HDD cages in the basement and put a quad radiator with 8 fans in there, as well as use extra 5.25" bays to put more 120mm fans in there (one fan per three bays).
