How many fans do you have in your case?
Majin
Count all the fans you have.
Front,side,top, bottom, vid card, cpu, all of them.
Lets see who takes cooling a bit too far. :D
I have the following in my CM Stacker:
Intakes
1 x 120mm front
1 x 120mm Front HD cooler
1 x 250mm MB cooler
Exhaust
2 x 80mm back bottom of case
1 x 80mm Top
1 x 120 mm back mid of case
PSU
1 x 120mm back of case near top
CPU
1 x 80mm
GPU
1 x 60mm? X850XT-PE
Chip Fan (NF4)
1 x 40mm
Total
11 Fans
Only 11 ;) In my Cheiftech Dragon
Intake:
3 x 80mm (2 Front, 1 Side)
Exhaust:
2 x 80mm (Rear)
1 x 92mm (Top)
PSU
1 x 92mm
1 x 120mm
CPU
1 x 92mm
GPU
1 x 80mm
Chipset
1 x 40mm
Noise:
Very Quiet
Edit: I can't Count :rolleyes:
Lian Li PC65-B
Intake
2x80 mm (front)
1x120mm (side panel over CPU and RAM)
Exhaust
2x80mm (rear and top)
Heatsink
1x92mm (blowing down, XP-90)
PSU
2x80mm (Antec SL 450W)
Video Card
2x40mm (BFG 6800 GT dual fan cooler)
Total
10 Fans
Noise Level
Pretty Quiet
It's quieter than my old Raidmax case that had 7 fans, including a low-speed 80mm and a VGA silencer for the vid card, so I'm pleased. That, and I got my XP-90 today and I can FINALLY overclock my 3.2 E. I <3 my XP 90. :D
Intake
2 x 80mm front
1 x 80mm side window
Exhaust
2 x 80mm
PSU
3 x 80mm
CPU
1 x 90mm
Northbridge
1 x 40mm
GPU
1 x 40mm
Total
11 Fans
i have a fan controler on 6 of the fans including the cpu fan, and the psu is a vantec stealth that varies the fans w/temp, its fairly quiet w/ all fans on low
Wow I only have 5 :( I really need to get some more but don't have anywhere to mount them.
80mm window mounted intake
80mm rear mounted exhaust
80mm CPU
80mm PSU exhaust
60mm GPU fan
I have 11...
2x front 80mm
2x rear 80mm
1x top 80mm
1x side 120mm
2x on vantec uv fan card
1x cpu cooler 80mm
1x PSU fan 80mm
1x tiny internal circulation fan
I am going water cooling soon and hope to reduce that number by a few. :) I am getting tired of the old turning the PC on creates a low pressure area in the room... doors get sucked shut, cats run, etc... lol
3. Originally it came with one case fan...which is starting to make rattling noises... :mad: stupid Dell crap. Will be replaced by a nice QUIET Panaflo. :)
1x 92mm main case/cpu fan
1x videocard fan (duh)
1x Antec PCI slot blower (made a huge difference in my setup)
Plus I took out all the empty PCI slot brackets from the back, took off the whole front of the PC and drilled 2 holes in the case. It looks ugly as hell, but hey, it's a Dell. Can't get much uglier than that. ;)
I have 6 as well
2 x 80mm in the back
1 x 80mm in the front
1 x 80mm in the window aimed at the gpu
1 x 92mm on the xp90
edit: oops forgot the 120mm in the PSU
Here's what's in my mountain mods case:
Intakes
4 x 120mm front
Exhaust
4 x 80mm back of case
1 x 120 mm back right on CPU
PSU
1 x 120mm back of case on bottom
CPU
2 x 80mm tornadoes on TT Silent tower
GPU
1 x 60mm? 6600GT supplemented by 1 x 80 mm
Chip Fan (NF4)
1 x 40mm
Total
15 Fans
3 :D
1x 120mm SilenX on my radiator @7v
1x 120mm Antec for exhaust in the back @7v
1x 120mm in my Seasonic PSU (not sure what voltage, but it runs very slow, and near silent)
I honestly can't tell when my PC is turned on unless I press my ear against it, or the hard drive is seeking. I even have the hd & power leds unplugged to further the effect :D
My case temps are always within a degree or two of room ambient temp, and my cpu idles at 38, loads at 43. My 6800gt idles at 44, and loads at 51.
Now if only I could silence the buzzing light bulb in my room....then I'd be happy.
Net Machine has the following:
2x 80mm intake
1x 80mm exhaust
2 on the PSU
1 in the CPU
1 on the Video Card
Editor has:
6.5" intake blowing across the 4 drives (this came from a CRT Data projector and has high CFM and low noise and will put a nice deep slice into your fingers)
2x 40mm exhaust
1x 80mm intake
2 on the PSU
1 on the CPU
Main rig:
2 120mm case fans
1 120mm PSU
1 80mm PSU
1 stock GPU (whatever size MSI 6800GT is)
1 92mm Vornado cpu
1 Northpole NB cooler fan (size = ??)
7 total
1x Blowhole Fan 80mm
2x HDD Intake Fans
1x Exhaust Fan 80mm
1x Videocard Fan
2x Cardcooler Fans 80mm
1x Chipset Fan
1x CPU Fan
1x PSU Fan 120mm
10 fans :D
Work/Net/MS Office computer has:
1 x 120mm Antec rear exhaust
1 x 80mm? Antec PSU
1 x 92mm Nexus CPU
Chipset fan on VC
Gaming box has:
1 x 120mm Nexus front intake
1 x 120mm Nexus rear exhaust
1 x 92mm Nexus CPU
1 x 120mm Antec PSU
1 x Zalman VF700-CU
1 x Noisy chipset fan
Intakes
4 x 120mm front
Exhaust
PSU
CPU
GPU
Chip Fan (NF4)
1 x 40mm
Total
15 Fans
This man is [H]ard
2x80mm psu
2x120 blue leds on my rad
1x120 12v on my capacitors and cpu
depending on my mood 2x80mm in the back and top
70mm vid card
40mm north bridge
Exhaust
2x 80mm in back
1x 80mm on top
Intake
1x 120mm on the side
1x 80mm in front
GPU
1x ??mm (6800gt)
Chipset
1x 40mm
CPU
1x 60mm (I think?)
PSU
2x 80mm
10 fans
revenant said:
I have 11...
2x front 80mm
2x rear 80mm
1x top 80mm
1x side 120mm
1x cpu cooler 80mm
1x PSU fan 80mm
I crap... I forgot about -
1x chipset fan
2x video cards fans
13 fans total
Hmm, let's see...
Intake
80 x 3
1 front, 2 side
Exhaust
120 x 1 Rear
CPU
120 x 1
Video/Chipset
60 x 1 gpu
40 x 1 chipset
PSU
80 x 4 (yes, stupid and LOUD AS HELL)
Total: 11
Need poll :)
Intake:
Front 120mm Thermaltake @ 5V
Side window fan: 92mm Zalman @ 5V
Exhaust:
150mm EBM (rated @ 24V, running @ 12V)
PSU: 80mm Panaflo high speed in PCP&C 510 Deluxe.
CPU: 92mm fan on Zalman 7000alcu
Video: NV Silencer 5
Intake
1 - 120mm
2 - 80mm
Exhaust
3 - 80mm
GPU
1 - 40mm
1 - 80mm
CPU
1 - 80mm
Misc
1 - 40mm (Northbridge)
1 - 40mm (Southbridge)
Total - 11 fans
I've got:
2x80mm front intake
2x80mm rear exhaust
1x92mm top blowhole
2x80mm PSU
1x80mm CPU
1x~60mm GPU
2x~40mm NB and SB :D
For a grand total of 11
These 80mm fans can get loud, I run the fronts together on on fanbus dail, same for the rear exhausts, blowhole, and CPU.
Total: 15
Case: CM Stacker
Intake:
1x 120mm for HDD
4x 120mm for my Heatercore
Exhaust:
1x 120mm back of case
2x 80mm bottom of case
1x 80mm top of case
Other Fans:
1x 60mm GPU fan
1x 40mm Chipset fan
2x120mm PSU fan
1x 120mm fan blowing my GPU
1x 92mm blowing my GSkill Rams
Intakes
1 x 120mm front
1 x 80mm side
Exhaust
2 x 80mm back middle of case
1 x PCI slot fan
PSU
1 x 120mm bottem of PSU
1 x 80mm front of PSU
CPU
1 x 92mm
GPU
1 x 60mm? ati 9500 pro stock one
wow 9 total go me
just for the heck of it....that's 198 total fans as of post# 24, and 24 total systems.
8.25 fans per system average.
Radiator:
3x120mm top "push"
3x120mm bottom "pull"
PSU
2x80mm exhaust
Chipset
1x40mm
Exhaust
1x120mm
Intake
1x80mm
AMC
3x40mm
Total: 14
wow...yall got alot of fans...thats the joys of modding..you can eliminate alot of the fans
what i got
1x 120 intake
2x80 exhaust
1x92 exhaust
1x120 psu
1x80 cpu
1x40? gpu
total in main rig-7
All quiet all pretty....i love it...can even tell when they on :D
Total in server-4
1x80 intake
1x80 exhaust
1x60 cpu
1x80 psu
hmm I can't count that high :)
intake:
2 80mm delta lower front
1 80mm panaflo high at lower front
2 sunon 120mm side case over MB
exhaust:
PSU 80mm
upper rear 1 90mm
lower rear 1 60mm
internal:
hd 1 90mm
1 90mm on main PSU
1 40mm on secondary PSU
CPU 92mm tornado
chipset stock and 90mm
memory 80mm and nidec 30? blower
video stock ultra
what's that 17?
Most rigged on various control circuits to run from 3v to 12.5 volts on seperate PSU. Most run at about 5V but can still be fairly loud. I'm putting in a window air conditioning unit for this room and it will do more good than all my fans combined (daytime room temps have been in low 30's C and it's not even real hot outside yet. There is a lesson in all this ;)
sarbz said:
just for the heck of it....that's 198 total fans as of post# 24, and 24 total system.
LOL
As of this post 15 Fans is the top spot.
Will anyone beat that?
I smell a mod coming on for someone
bimmer01 Total: 15 CM Stacker
How the Hell did you fit that many fans in there?
You got to show us a pic.
sweet merciful crap! Now I /know/ some doors slam shut when he fires that sucker up.
Majin said:
LOL Now that guy is [H]ard
He wins "Fans" Down.... :p
yeah, he's a real fanatic when it comes to fans....
sorry, that was really dumb, but i couldn't resist
Intake:
120mm
80mm
Exhause:
2x 80mm
CPU:
stock fan
GFX:
stock fan
PSU:
stock fan.
Total:
7 fans.
depends on what i'm doing
2x120mm case fans (antec super lanboy)
1x50mm fan (6800gt)
1x90mm slot blower (ram cooling)
2x80mm fan (ocz powerstream 420)
2/1x120mm fans ('77 bonneville HC)
8 total.. not too bad, and load temps are 32c right now with 1 fan on the HC :D
in my secondary rig:
3x80mm case fans
1x92mm
1x80mm both for true430
1x80mm for the slk-800
1x40mm for the video card
7 total. getting better
the laptop next to the secondary rig:
1x???mm
1 total! yay
2x80mm intake
1x92mm intake
3x80mm outtake
1x92 cpu
a fan for my north bridge
and a fan for my graphics card.
I guess that makes 9 total.
3 in total
one for video card, one for psu, and one for heatsink
quiet than a mfer
2 x 80mm intakes
2 x 80mm exhaust
1 x 120mm CPU cooler
1 x GPU cooler
1 x 120mm PSU fan
7 fans
120mm Sunon intact ducted onto HSF
60mm Coolermaster mounted on HSF
Vantec Orb on GPU
PSU fan.
I don't have exhaust fans because I don't keep the side panel on my case,
