How Low Can You Go?
Carnival Forces
Competition!!! :D
Rules: go download rthdribl here: http://www.techzonez.com/forums/archive/index.php/t-6434.html
1. Using your Video Card's Drivers, set AA and AF settings as agressive as they will go. Be sure to choose "Quality" for the filtering method.
2. Set your Screen resolution to 1024 by 768 pixels
3. Set your Color quality to Highest (32 bit)
4. Unzip / Start up rthdribl and use the following settings:
A)Options / Glare / Check Halo
B)Options / Glare / Check Soft Glare
C)Options / Glare / Glare Type / Check 10: Spectral Sunny Cross
D)Options / Make sure Fersnel Effect, Fill Inside Transparent Modelt, and Detail Maps (fleck, bump) are checked
E)Options / Material / Material Type / Check 25: Ruby
F)Options / Depth of Field / Depth of Field Type / Check 4: 6-Blade Iris (141 Taps)
G)Options / Multisample / Check 16x Multisample 8
H)File / Config Settings
--Make sure the following are as follows:
Display mode settings: Windowed
Back Buffer Format: D3DFMT_X8R8G8B8
Depth/Stencil Buffer Format: D3DFMT_D16
Vertex Processing: PURE_HARDWARE_VP
Present Interval: D3D_PRESENT_INVTERVAL_IMMEDIATE
G)Maximize the window, but don't go full-screen
5. Let it run for about 5 minutes, looking at your FPS, note the lowest it gets
6. Report your FPS w/ a system run-down and video card drivers
here's mine:
Lowest FPS: 1.47
CPU: AMD64 3200+
GPU: Sapphire Radeon 9800PRO 128MB
RAM: 256MB GEIL PC3500
Mobo: Chaintech ZNF3-150
Chipset: nForce3-150
Video Card Drivers:
Driver Provider: ATI Technologies Inc.
Driver Date: 12/12/2003
Driver Version: 6.14.10.6414
AA and AF Settings:
AA: 6X
Filtering method for AA: Quality
AF: 16X
Low : I saw it drop to the mid 20's twice
CPU : 3hz P4
Mem : 1gb Kingston hyperx pc4000
GPU : x800pro
Mobo : Intel 865gbf
Drivers : 4.7s
Max settings.
Those settings looked pretty cool, I could sit and watch that program for hours. oooooo ahhhhhhh pretty.
Decided to do this while I reload a freinds old POS compaq. Course you never said to go full size window mode or stay in the 640x480 default size.
anyhoo
Edit new lowest: .40
Lowest FPS: 2.53
System: Tigershark (see sig)
Driver version: 6.14.10.6458
AA:6X
Quality
AF:16X
Hell I wish newegg would get these new cards in stock. I'm framing here! :eek:
ahh! my bad...
i forgot to add, maximize the window, but don't go into full-screen mode
sorry you guys :(
CPU : 3hz P4
GPU : x800pro
Mobo : Intel 865gbf
Drivers : 4.7s
Max settings.
you forgot a few settings then.....hehe
Lowest FPS: .49 (ouch)
CPU: P4 3.0 @ 3.6
GPU: 9800PRO 128MB @ 425/360
RAM: 1Gb Corsair PC4000Pro
Mobo: Abit IC7-G
Chipset: 875P
Video Card Drivers:
Driver Date: 06/10/2004
Driver Version: 6.14.10.6458
Maintained a steady 20+ and dipped below 11.8 fps ones at a screen change :D
mind posting system, vid card, vid card drivers...
that seems highly unlikely... i don't think you got al the settings right :p
OK....
AV8 Deluxe with 3500+
1gig OCZ 3700 EB
X800Pro (560 core / 580 mem)
CAT 4.7
Ran again with same results......
the detail fleck bump map is prob the single most hit you will take to framerate on that demo...
it kills the framerate..
and you cant even see it on the planets , the skull in jade does nicely..
you should have mentioned material btw..
i think i got down to around 4 fps on this system running the correct settings...
let me point out to you where i did, btw...
Competition!!! :D
here's mine:
Lowest FPS: 1.47
CPU: AMD64 3200+
Video Card Drivers:
AA and AF Settings:
AA: 6X
AF: 16X
LOL, i get the same "Not enough Video memory" error. probably an Nvidia driver issue or something. what drivers are you using?
I've installed DX9c, the DXsdk, Forceware 61.76 and I get this error when I start it up:
Warning: Nothing will be rendered.
The reference rendering device was selected, but your
computer only has a reduced-fntioanlity reference device
installed. Install the DirectX SDK to get the full
reference device.
Gerneric application error. Enable
debug output for detailed informtion.
This sample will now exit.
oh yeah:
Athlon 1800+ stock
Ti 4600
installed.
oh yeah:
Athlon 1800+ stock
Ti 4600
It might be because the program is DX9 based. And Gf 4 is DX8.
