Flyboat said:Thanks for the replies. Since SFF is smaller, would it have alot of overheat problem? would it be very easy to fry the cpu and motherboard? I know my ATX will have overheat problem if I don't clean it within 6 months ( I have three fans in the ATX case).
This is true for SFFs like Shuttle and the iDeq, but for uATX motherboards, the upgrade path is just like a regular ATX path.eastvillager said:Odds are pretty good you won't be able to upgrade the motherboard in your SFF, so if that is something you'd normally do during the lifetime of a case, then realize you'll be looking at a new SFF case.
eastvillager said:The only gotcha with SFF is usually the motherboard(at least with respect to longterm upgrade options) .
