How long will it live?
Dunno7
I think it showed up 6 months ago. It was a bit smaller than now.
What is this thing? I guess I should start looking for a new monitor?
oqGPxQn
https://imgur.com/a/oqGPxQn
oqGPxQn
oqGPxQn
oqGPxQn
Only your imgur link is working. Not sure what I'm looking at, are you talking about the horizontal grey striping?
You can drop/drag images on your PC directly on your posts. Just make sure you pic "thumbnail" or "full image" before posting, or thumbnail will be default.
No the vertical one on the right that goes from top to bottom
