MondGsicht
- Jun 13, 2003
Hi
I would like to know, how long it will take to do 1 WU on a P4C 3.0?
THX
THX
No, it is Pageian's faultOriginally posted by pageian
Stressing the main rig is good. Just think of it as a way of finding the bottlenecks in your system and helping you decide what components need to be upgraded. Once you starting stressing and then upgrading your main rig you'll soon have enough spares for a 3rd rig, then a fourth etc etc.....
Unless your main rig is hooked up to your life support machine or something then there's really no reason to worry about stressing it with fah. I've never had a rig die as a *direct* result of the fah client. Now rigs will die from, lets call it aggressive overclocking, but that's not fahs fault.
Originally posted by AtomicMoose
No, it is Pageian's fault![]()
My personal opinion is that the mojo got to himOriginally posted by pageian
Well back on topic, where's relic when you need (to blame something on) him???
That sounds like some kind of euphemism.Originally posted by pageian
"I'm not in the mood anymore, honey. I just got done stressin' the main rig.
You are not right....Originally posted by Mattman
