Between five and six hours at the most, but that's during rather light usage. Surfing with wifi and listening to music, maybe three to four hours, depending on how bright your backlight is.
My 15" PB battery lasts for 2:30-3:00, and close to 4:00 if i've got the screen off and am just listening to music. Sometimes i'm running everything full-bore, and sometimes i'm very conservative. My PB is ~1.5 years old.
edit: i know that's not the Apple line you're looking for info about, but i just thought i'd add my $0.02.
If I'm sitting in class just taking notes (long pauses of non use), it can last through a 3 hour class easily with still 2 hours left of charge. Like others have said, with the airport on and using it a bunch to surf the next I probably get 3.5 hours.
just curious cause my vaio surfing the web on wireless will burn through in about 15min. The mac site says battery life will last 6 hours. So thats prolly sitting typing with no wireless. Does it make much difference between the 12in and the 14in. Which is better would u say?
Well, that depends. They have the same battery time, the same (more or less) performance and the same resolution. The 12" is smaller and lighter (and cheaper), but the 14" has a slightly larger display. If you want a larger display (due to poor eye sight or whatever), the 14" is a good choice. However, the 14" isn't the same kind of bargain. There are plenty of <$1000 15" PC laptops out there, and many of them outperform any iBook. However, if you look at 12" laptops, the iBook has the best price-performance ratio of all laptops I've found.
Well my Vaio is a P4 2.79Ghz with 512 of ram qith a 15in screen but it's not worth it when at max I can get about an hour or hour and a half out of it w/out wifi on
