Capacitor aging in modern power supplies rarely becomes significant for 10+ years, especially in quality power supplies.
Heh......I had a 300W Fortron last me 2 days...........another 1 year......they were cheap.
I've got an 850 W PC Power and Cooling server grade PSU that is still running strong after 10 years.
Most of my Corsair's are between 1 and 6 years old and have never missed a beat.
With proper cleaning, they can last more than 10 years.
the most important factor is power input...
I have to agree here, yes the quality of the device plays a huge part in the life of a PSU, but all electronics are best served with regulated and conditioned power. By using a good rated and quality UPS (uninterruptible power supply), the power conditioning being sent to the PSU for the PC will allow those things to last much longer than most because of the ballanced, constant, and conditioned power.
I run a UPS dedicated to just my PSU for Frank...
I've had about as many Teapos as Fuhjyyus fail in PSUs, mostly in the +5Vstandby circuit of old Antecs, but PC Power & Cooling uses them in some of their products without much trouble, including those warranted for 7 years.
I'd like to see actual quantifiable data on that point. Quality power supplies have several protection mechanisms to prevent damage from power surges. As well as being able to supply adequate DC voltage during periods of below standard power ("brownouts"). For DC devices, the currents that flow through them are not simply proportional to the voltage supplied to your power outlet.
I'm on 8 years on my 850w Thermaltake Toughpower. It's in its 3rd PC.
Caps and solder joints looked good on last check. What am I looking for with the glue??
If the PSU is a good quality unit to begin with, AND the fan doesn't fail, AND it not pulling a 100% load 24/7, AND it's not abused with cig-smoke, cat hair, Coca-Cola, etc, AND the input power is clean then it should last you long enough until you need a higher wattage unit or until want to get a new shiny one.
I have two Yamaha P2201 Pro stereo amps, 230wpc or almost 700wpc bridged mono, made in 1976. All original capacitors and still going strong after almost 40 years.
And there are people who think caps die after only a few years? I guess anything is possible with a cheap enough Chinese component.
