how long could a USB cable be?
chronic9
I have a 9 ft. long USB 2.0 cable that is plugged into my scanner, but its not long enough to reach my PC, since the scanner is behind me on a smaller table. If i plug this 9 ft. cable into a 3ft extension it doesnt work, just detects the scanner.
i was wondering if I would buy one 12 ft. + USB 2.0 cable would it still work? Is there a limit on how long a USB cable should be?
16 feet if I remember right with out some kinda of repeater/hub. The 3 footer may also be a bad cable.
5m. However, if you cascade 5 hubs with 5m USB cables, this will allow you to connect a device 30m away.
1m = about 3', your 12' cable is OK, add the extra 3' is over by just a bit which shouldnt be a problem. Be sure both cables work tho by trying them seperatly.
You have to walk 12ft to use your scanner? Maybe it is time you thought about moving the scanner closer?
i can make it look UGLY with a 6 ft cable.....
the black object on the back table is the epson scanner.
the 3 foot extension works fine on its own its weird... i guess ill buy a 15ft or w.e USB 2.0 cable and be done with it.
