How is this temperature?
Aelfgeft
XFX 6600GT 128MB DDR3 I just got.
According to Rivatuner, I'm getting about 54-55C...is that high? Should I be aiming for like CPU-type 30s or is that not realistic? If so, how should I cool it?
Second, according to RivaTuner the core is at 300MHz. I thought these came at 500.
first off you are talking about 6600GT not Ft, right? lol
well anyway i am not the best at dealing with Nvidia cards, but your temps should be in high 20's, mid 30's when its not on full load
Yup GT my bad. :)
So you're saying it's running hot? Because I just stuck it in, haven't done anything to it.
Negative.
Those temps are more than OK. You're fine. Video cards run a little warm, especially the GT's. If it gets into the high 80's-90's, then you can start to get nervous.
Idle: 50's
Load: 60's
(in general)
