I am putting together the following as upgrades to 2 of my PC's, with one getting a new case and a new monitor. Both are getting speaker upgrades, going from 2.1 to 5.1. So, I will not list CD drive, floppy, Vantec rounded cables, etc. since they don't matter. But please, anyone tell me what you think and let me know if you see any compatibility issues or other improvements I could do. I conducted a lot of research and this is what I came up with, which will make pretty state-of-the-art rigs for now. Newegg is my source of course since they have never let me down in many years of building PC's. I will not be overclocking or using the SLI function since I am paying a lot for these 2 systems, but not so much that I want to buy 4 video cards.
AMD Athlon 64 4000+ - OEM (I am partial to AMD)
Asus A8N-SLI Deluxe - Retail (nForce 4 is the way to go I believe)
Corsair XMS Twin1024, 512MBx2, DDR400 PC3200, Non-ECC, Unbuff, 2-3-3-6 T1 - Retail
Antec Plus1080AMG Case w/430W PS - Retail (I already have 3 of these and I love them)
Asus ATI Radeon X850 XT Video Card 256MB GDDR3 - Retail
Maxtor 300GB 7200 RPM SATA 150 HD w/16MB Buffer!, 6B300S0 - OEM
Viewsonic E90FB 19" PerfectFlat CRT Monitor - Retail (Not willing to spend for LCD's)
Zalman CNPS7700-CU CPU Cooler - Retail
Altec Lansing GT5051 5.1 Speaker System - Retail (Not willing to spend for Klipsch, etc.)
Vantec Thermoflow Variable Speed 80mm Case Fans, TF8025 - Retail
Belkin 5-Socket Power Center, F9M520-08-GRY - Retail
Also, I am getting 2 new HD's for my other 2 older systems, to replace smaller EIDE drives, so anyone let me know if you heard anything bad about these:
Hitachi 250GB 7200RPM SATA HD w/8MB Buffer, HDS722525VLSA80 - OEM
Coolling Questions I have about this setup:
1) Which Zalman is best and why is the CNPS7000A-Cu $20 more from newegg than the one I have listed above?
2) Is there a better 80mm case fan I should consider other than the Vantec? It seems to do really well for the price ($7.49), up to 3400RPM and up to 41.6 CFM with a noise level that should not be too bad.
3) I want to buy 2 of these case fans per PC (the 1080AMG case comes with 3, 2 out and 1 in on the side). Should I switch the 2 out fans on the back with the better ones I buy or use them to pull air in at the front? What I am asking is, is it more important to have better air movement out than coming in? I think it makes sense that way.
Thanks in advance for your help.
