How is this PSU?
Any of the following brands are decent:
* Antec
* Fortron
* Enermax
* PCP&P (PC Power & Cooling)
* OCZ
AlexStenka said:
Aspire isnt exactly a highly thought of brand
but then with no idea of what your trying to power, I couldnt say
watts mean very little these days are the amps on the right rails? are the ratings done at a reasonavble temperature? did they lie or cook the books any other way?
are there any "special" considerations or use?
all these things go into choosing a supply that will do the job
I can think of a few 350 watt supplies that might out perform that 600 watt
depending on the config
there is a sticky on how to buy a PSU (and how to ask for help)
if youve done that, well what are your amp requirements?
a little cut and paste
courtesy of Mike Chin at SPCR and Dan of Dan's Data
POWER SHMOWER
or How PSU Power Ratings Mean Almost Nothing
A frustrating fact about PSUs is that there does not appear to be a stringent or regulated standard for reporting, advertising and labeling rated power. This is despite the existence of standards like ATX2.03 or Intel ATX12V.
There are well-established standards for measuring and rating HDD capacity, an engine's horsepower, or the heat generated by a furnace... but not one for how much power a PSU can deliver. There are so many cases of people with "450W" PSUs having power stability issues running a system that can't possoibly draw more than 150W. And "300W" units that keep running where the "450W" units are faltering.
It's not just about bad PSUs vs better ones. It's a dumb situation caused by uncontrolled marketing competition. Real regulation would bring PSUs out of snake oil territory and into a more sensible consumer-friendly terrain.
There are many ways PSU makers fudge to make their units seem more powerful.
1) Out and out lying. You add up the power on all the lines in many PSUs and they fall short of the rated power by 10, 20 30W or even more.
There are more sophisticated ways:
2) Limit the AC input voltage to a very narrow tolerance. The best PSUs are able to deliver their rated power given a decent range of AC input power, say 90~130V for a 120V unit. It's much more demanding to produce 300W w/90VAC input than with 120VAC, so what some PSU makers will detail in their tech specs (usually not in their consumer brochures) is to specify 115-120VAC for input power. A PSU specified this way will not deliver full power if the AC voltage sags, if there is a brown-out. Surely it causes instability more often than a PSU rated to deliver full power with 90-130VAC.
3) Specify a low operating temperature for rated output. This is quite common, but again not often seen in consumer brochures, but rather tech spec sheets provided usually only on demand by engineers or corp buyers. A typical PSU operating temp statement is somthing like this:
0ºC ~25ºC for full rating of load, decrease to zero Watts O/P at 70ºC
Examine what that says. Full power (let's say 400W) is available when the unit is at 0ºC ~25ºC. Hmmm. Think about this.
Have you ever felt air blown out of a PSU in a PC running absolutely full tilt (which it would have to do to get anywhere near 400W output) that felt cool to the fingers? 25ºC airflow would feel exactly that: Cool, given that normal body temperature is 37 °C.
So this PSU cannot deliver full rated power when its temperature goes over 25ºC. OK, what happens to the max power output capacity above that temp? It decreases gradually so that by the time the PSU temp reaches 70ºC, the PSU cannot deliver any power at all. So if you assume that this power drop as temp rises is linear, then max power capacity will drop by ~9W for every degree over 25ºC.
Now having examined as many PSUs as I have over the last 2~3 years, I have to say there's not a single PSU in ANY PC I have ever used or examined that would not measure at least 30~35ºC almost anywhere inside the PSU under almost any kind of load. And if/when it is pushed, 45ºC is nothing at all, especially for or near hot running components like voltage regulators.
So let's say 40ºC is a fairly typical temp inside a PSU. This 400W rated unit would actually be able to deliver a max of just 220W at that temp. Hmmm. Interesting, isn't it? At 50ºC, the available power would drop to just 130W. No wonder some PSUs have 3 fans each capable of 50 cfm!!
Here's a simple fact: Really high quality PSUs are actually rated for full power output at as high as 40ºC. The trick is get a hold of the spec sheets that tell such information so you can compare apples to apples. Or ask.
from dansdata
Unethical PSU Marketing 101.
Here's how to make overly optimistic power supply specifications. It's really simple.
First, power the thing up. You can make an ATX power supply that isn't connected to a motherboard turn on by grounding pin number 14 on the big motherboard power connector. It's easy to spot that pin, because it's the only one with a green wire going to it.
Use any handy bit of wire - like the paper clip in this picture - to connect pin 14 to any ground contact. The ground contacts are the ones with the black wires going to them. Presto, the PSU will turn on.
Now, break out your brick-sized power resistors and load the heck out of one of the output rails - the +5V rail, for instance. Measure the current as you increase the load, until the voltage sags unacceptably far below the rated voltage.
How do you tell what an unacceptable voltage sag is? Well, you could choose a nice conservative small permitted sag - say, 0.1 volts - so that your results are genuinely useful to your customers. Or you could just ignore the voltage and say that when a fuse (or some other component...) blows, that must have been the limit, right there.
OK. Now you've made a big fat amperage number for the +5V rail. If you blew up the PSU in the process, get another one, and repeat the process for +12V and +3.3V, and for the low current rails as well.
On no account, though, should you test more than one rail at a time. This is the key to the whole scam.
A big beefy PSU may be able to deliver 50 amps (say) on the 5V rail when nothing else is under load, and 25 amps (say) on the 12V rail when it's similarly all alone. But the 12V and 5V rails together may only be able to deliver, say, 350 watts between them, when they're both under load. Watts equals amps times volts.
In a real PC, all of the power rails will always be under load together.
But you're not testing what the PSU can really do - you're making pretty numbers for the sales brochure!
So test all of your rails alone, get an amperage figure for all of them, multiply that figure by the voltage of the rail it came from (the nominal voltage, not whatever the voltage had sagged to as the PSU pumped electrons through the dessert spoon you'd soldered to the circuit board), then take all of the resulting wattage figures and add 'em up. That's a wrap, folks. Ship it!
Power supplies become increasingly expensive
When I initially asked about this on a mailing list, Solaris x86 advocate Al Hopper told me I was drowning in my tea, and that it was "all very simple". I love the simplicity of Unix people.
He explained that the later P4 CPUs take their power from a 12 Volt feed and, using the onboard voltage regulators, generate the high current, low-voltages they need to operate (anywhere from ~ 1.6V to around 2.7V). So the first requirement is a PSU that has plenty of power available from the 12V supply. Since the older ATX compatible PSUs didn't supply much current from the 12V section you have to ensure that your new PS delivers enough current (or power in Watts) from the 12V section. That's why using your old P3 ATX PS is a big "no-no".
He then described the history of the post-P3 power supply mess:
The earlier Athlon motherboard manufacturers decided to solve the 12v problem by using an additional 4-pin square connector to get the extra 12V those CPUs required. However many older PSUs didn't provide the 12V 4-pin square connector.
The motherboard makers then wised up and decided that there was nothing magical about a square 4-pin connector, so they put a normal hard disk type socket on the motherboard and provided the 12v power via a standard hard disk (4-pin inline) connector. Problem solved - you may now use your older PSUs provided they supply sufficient 12V current (many did not).
Further confusion came from PSU manufacturers not specifying the capabilities of the PSU in a way that allowed the end user to verify it's 12V power output rating.
In the meantime the ATX spec was saying "use the new 6-pin" inline connector - and very few motherboard makers implemented it.
Just to be sure, some motherboard makers, implemented *both* the hard disk style 4-pin inline connector and the square 4-pin connector. They said "use either or both in any combination you like".
The spec then evolved to the 24-pin main connector. Again, most motherboard manufacturers did not wish to make their customers mad by mandating that they replace their power supplies. This might cause their customers to avoid motherboard upgrades. Some used a "special" 24-pin connector with the extra 4-pin connection blocked off, or colored so that the user could plugin a 20-pin plug into the correct end of the 24-pin socket on the motherboard. Many others simply ignored the 24-pin requirement in the specs. Again - problem solved - use your older PSU.
total wattage means absolutely nothing if its capacity on the wrong rail, or if its "ghost" capacity that simply isnt there when a supply is derated for temperature
you learned how to integrate components and employ your OS, well now-a-days, you need to learn how to buy a PSU or risk frying some pretty expensive components
there are plenty of object lessons to go around
options have become fairly limited learn or burn or pony up the $$$ for overcapacity
we are happy to help, but need you to invest a bit of time for your own config and a small learning curve which will pay dividends indefinately ;)
