So I bought another XSPC rs240 kit for my gamming rig. Without even installing it I picked up some parts to upgrade it(I got a great deal on the parts). This is what I have gathered so far and this is my plan.
PARTS:
XSPC rs240 kit(rasa block, rs240 rad, hose fittings, etc)
2x MCP350
1 Swiftech 320 drive rev2 rad.
(havent picked out gpu blocks yet)
The Plan:
This is all going into a haf932 case. I will be trying to cool an i7 920@4ghz and 2x 5870's. I want a setup that is going to last me awhile.
What I am thinking is, installing the Swiftech drive rad up top with one MCP350. Installing the rs240 from the kit on the bottom of the case with the other MCP350. Then adding another 1x120 rad on the back(so the CPU will have a 320rad to itself, and the GPU's will have a 1x120 and 2x120). Now what my real questiona are. Will I get any benefit having another 1x120 rad? Should I break this into 2 loops since I will have 2 pumps, or one large loop? The number one question is can 2x MCP350's handle the loop? I dont mind having to much cooling, but I want to future proof myself when I upgrade to new GPU's and future CPU's. Also I dont plan on using the Pump/res that comes with the XSPC kit... or should I?
PARTS:
2x MCP350
The Plan:
