because you are broke from buying the cards/mobo/CPU to run it all!If you can afford three of those, why not run a Liquid cooling set up for all those?
It was also RIDICULOUSLY loud. All of the cards from the Dustbuster age suffered similar problems- FX5800, X1800 and X1900 dual-slot coolers were all similar, and similarly short-lived.Yeah, I've seen that pic and others like it before and wondered the same thing. It's obvious not much thought goes into the construction and design of these cards. They should have a cooling solution similar to my old x1900xtx which had a fully enclosed fan and sucked air in from the back of the card and blew it out the front. It was by far the best cooling design I've seen for a card. My guess is that the moved away from that method to cut costs.
Why would you ever need three of those to begin with? lol
