Drive mount fan controller. Real simple. Game or bench, reach over and turn up fans as needed. Too loud? turn em down.
For someone concerned about dpc latency I believe a hardware solution would be the best![]()
Some have nifty things like multiple temp probes and whatnot as well.
"I'm looking for a way to better control my fans as BIOS is quite limited."
If this is from personal experience then state the BIOS limitations you've noticed.
Other than ease of use, pretty graphs and eye candy, what advantages do you see these MB utilities offering? They're for reviewers (being part of the MB package) and newbies to use IMO. Most experienced users avoid them completely due to issues they often create.
Three major ones with an Asus X79 board:
- it has 60% as the lowest setting for case fans
- it ramps them up and down too aggressively, making any short CPU load changes annoying
- all the fans are controlled only by the CPU thermal sensor
Custom fan curves and limits and custom sensor linking.
Anyway, I got SpeedFan working and so far it's working great and shows no signs of messing with the DPC. Custom fan curves and limits, CPU and case fans are CPU temp controlled, the latter ones are also GPU temp controlled.
FWIW, just about all the above Asus Q-Fan BIOS control limitations have been addressed in later/latest boards except the ability to link fans with off-board sensors like the GPU.
