Finally, I upgraded from my 939 system and got myself a Q9300.
I've pumped it up to 3.5GHz (467x7.5) @ 1.37v and it's has being running prime95 for about 8 hours so far. the load temp is around 72C - 76C (in CoreTemp). Could I have pushed the chip for more? Should I worry about the temp?
I had tried to push the chip to 3.6GHz the day before, but I was not able to make it stable even when vcore are set to 1.4v, and it was running around 82C loaded which I thought it was too hot. What actually is the safe temp range for a Core2 Quad?
