How is E-power?
ElementK
I was considering the Jaguar 450. This would be a big investment and I wanted to know if they were reliable. I readf the sticky above, yet my Raidmax power supply has been fine. Also, if Epower isn't good, what is the best Entry-level PSU to run an EVGA 6800 Limited?
while I cant say definatively, its likely a rebranded Topower with bells and whistles
likely the TOP-450P5
the Tagan 480 in their line certanly is
which would make them high average PSUs
provided they arent overloaded reliable workhorses
with basic spec compliance in this case to ATX12V v1.3 which isnt the lastest spec
you might consider the new Fortron Blue Storm 500W for an ATX12V v2.0 Id consider "entry level"
has dual +12V rails for a total of 30A compared to the Jaguar with only 28A
as far as running a given config
youd need to run the numbers
