I'm buying the DD RBX and the Swiftec MCW50, can I get away without a chipset waterblock for the time being?
My board isn't volt modded yet but will be when I take it all back apart for the water cooling install.
I definitely don't want to add noise (small high-rpm fan)
Also - does anyone have a link to the big thread on bong coolers saved? Search isn't working and I've read back several pages already....
I'm definitely going to use a "bong" setup with it vented through my window (using a painted board with a hole cut in the end just tall enough for the pvc to vent through -
so it's still basically sealed from the outdoor air)
I plan to use a 4" pvc pipe approx. 3' H and another 2" clear pvc pipe attatched to the side w/ a 90* fitting near the bottom as a resevoir (like a pet feeder)
Anyone want to buy a like-new Zalman 7000cu?
Oh - nice forum btw.
