How important is Video Card for Adobe stuff?
The Chosen One
Hi guys, im building a comp for a friend of mine, and she does a lot of Design-type work on it. You know, posters, book jackets, websites, that kind of thing, and basically uses Adobe Photoshop/Illustrator etc and Dreamweaver.
She doesnt want to spend a great deal of money (but lets face it, who does), and im already making sure she'll have plenty of ram cos i know what a RAM hog, Adobe stuff is.
But what im not sure about is its video processing power requirements.
IMO, its not doing any video processing, its not rendering the sort of 3d environments that a game would require, so it shouldnt need that beefy a card right?
Although i do seem to recall someone saying that was wrong.
So basically, does it matter that much? and if so...what should i get?
Thanks in advance guys.
put money into ram and the most expensive dual core processor that her buget allows. She'll see the most gains there........
Edit: as far as processor, obviously that is a general direction, you'll need to google for info on just what exact processors will work most effeciently for her needs.........
yeah, it won't matter much, only advice would be to get something that is dedicated to graphics to make sure it offloads as much as possible from the CPU. I'm not talking much, like x600 or geforce 6200 (non-turbo cache).
For Photoshop, beefy processor and no less than a gig of RAM. Same goes for most of the others actually...if you actually use Premiere as your capturing program (I use other software, then import into Premiere) HDD speed would be an issue I'd think, but none of the Adobe apps need a super beefy videocard afaik. Though, in Premiere Pro 2, I noted a bunch of "GPU Effects"...probably some stuff any DX8/9 card can handle.
Oh yeah, I know how much the graphics type love their huge monitors...if your friend actually goes for something with a giant resolution like those Apple 30" monitors, you'll need something with dual-link DVI (IIRC that's what it's called...a standard DVI connector can't transmit that amount of data...this, iirc, combines two DVI outputs into one physical connector to drive those huge ass displays). Should probably double-check that though.
yeah shes already attacked the comp budget to get an LCD screen (what a waste). hehe. But okay, thanks for the confirmation....processing power and RAM, just what a thought.
Thanks again guys.
QFT~!
Im a major multitasker especially with adobe/macromedia stuff... I recently grabbed one of the Dell Deals for an Intel D 820 and upgraded to 1.5gig ram.. the video card is a pile of crap - ATI X300... and it works fine for doing anything i've thrown at it desktop wise. Running on a 24" widescreen CRT
The ram is a big deal, the FSB is the other big deal.
