Athlon 64 3000+ Venice Rev. E6
Asus A8V Deluxe Bios 1014
1GB Corsair PC3200 ValueSelect C3
Now, the RAM:FSB ratios on this board are a little trickier, since they don't go by 1 to 1 ratios. Instead they go by DDR speed:FSB. Therefore, normally it would be 2:1 to represent DDR400 to FSB of 200. Calculating things isn't a big deal, but the board sure seems to have troubles with it. At the moment, I'm running at 223FSB, with a 5:3 ratio (next down from 2:1) and CPU-Z is picking up the memory at 200.7 MHz. Let's check our math:
223 / 3 = 74.33333
74.33333 * 5 = 371.66666 <--- supposed to be my effective DDR speed.
Hence, the memory would be running at 185.83333 MHz. Apparently my board is rounding up, which doesn't entirely please me.
Anyways, I tried going for the 3:2 DDR:FSB ratio, and cranked up the FSB to 260. Stuck at the Windows XP black loading screen. So did 250. I figured running my RAM so low just to get my CPU up would actually put less stress on it. Could it just be stiffness of my RAM? I'm also running a 431W Enermax power supply with only 20A on the 12V rail. Would that make a big difference at this stage?
I figure I could get higher than 2.0GHz at least.
223 / 3 = 74.33333
