how high is your venice 3000+ oc'd?
Elysian
in the spirit of the 4000+ thread, i was curious how high other people's venice 3000+'s are clocked at... mine was 2745 on stock hsf, and now only 2800 on water...
whats your stepping?
I'm 2750 = 250 X 11 on water really stable, but need to reload windows, Ill see if I can get it a bit higher tonight
i dunno what stepping it is, i just know its a E3 revision
as for the specs of the rest of my rig, i'm running on an Epox 9NDA3J mobo, 9800 pro vid card, and water cooled with a swiftech MCW-5000(figured out a way to make it work with the stock retaining mechanism for my 939, even though the block is for a P4), and running a Hydor pump and some other pump thats built into my reservoir... and a 2x120mm radiator... right at this very moment, i'm running 2 power supplies, 1 being an antec smartpower 350w(powering mobo and vid), and the other being a truepower 330w, powering everything else... temp solution till i get a better power supply...
mines i think week 17? i just pulled the numbers off it, i think its the 0517 number that tells you the week? and with my rigged up dual power supply i'm at 2808 stable... time to really crank it up and see what it can do.
edit: nope, looks like i'm peaked out... oh well i guess, i'll have more fun with overclocking when i get my x2
that still a great OC, week 17s are one of the best, if not THE BEST, weeks in the venice line
it just bothers me that the difference between water and stock hsf was only 55 mhz... i've never had a processor act like this, and now i know its not psu related... maybe its mobo related i don't know... i mean i can post at 320mhz fsb, theres gotta be some reason why i can't boot to windows at that speed(which is only 80mhz higher than i'm at right now, and i'm only at .25v overvolt on the vcore, whereas even at .35v overvolt i can't boot into windows at 2880... even with my mem down to the lowest possible ratio, nocando)
I'm by no means an AMD expert (though by christmas i want to be! :p), but I read a lot on forums. Have you messed with the HTT? I've read several places that you need to change it (to what, I don't know) in order to get a good OC. A quick search might help you out... just something to think about in case you hadn't already thought of it! :)
yes, i'm on a HTT of 3x.
I'm only getting 2.4ghz with 267mhz X 9 and 4x htt multi so 1067mhz. My voltage in bios @ 1.425 but i think programs read it @ 1.39 from 1.36v stock? My divier is @ 4/3 to keep my crappy ram around 200mhz. What else could i do to oc this? I have an XP-120 and DFI LANPARTY UT ULTRA-D motherboard. My revision/stepping is DH-E3. i think its a good oc from my 1st. Went from a 3000+ to eqivalent to a 3800+ (34% oc). My cpu runs from 25 to 28C idle and 28-32 underload.
I'm doing 2.75 with my 3000+ 305x9 with G.Skill LE TCCD at 305. 1.64vcore on water cooling.
Mine craps out if I get the fsb above 270, regardless of multipliers for some reason. Not sure why. I had it at about 2400, but I decided to lower the voltage and set it to 2200. Not too impressive, I know, but I might try to mess with it later.
probly not a bad idea to post this stuff too,
anyone know any tricks to make my cheapo mem more efficient? my p4 i875 rig had much better mem bandwidth than this one, with the same exact sticks, at the same speed. i also find it very funny that the bios shows the mem running at 207, when IRL the mem is running at 208... anyone have this issue on a 9NDA3X mobo?
2.7GHz daily 300x9, memory on various dividers. 2.86GHz SuperPI 1M Stable with 1.66v. Air-cooled with a stock X2/FX cooler.
you're the one who had the superpi results at 2860 mhz, like 27 sec i think, i don't get how you are getting to 2860 on air when i can't even get over 2800 on water :(
Super PI 1 mb is HARDLY anything stable. Even 32 mb is not a good stability test, though it helps to let you know if it has potential. It's all luck of the draw with chips man.
ShuttleLuv said:
Super PI 1 mb is HARDLY anything stable. Even 32 mb is not a good stability test, though it helps to let you know if it has potential. It's all luck of the draw with chips man. Don't let the people at xtremesystems or somewhere's overclock let you falsely think all cpu's will do XXXX speed. Every chip is different and there's a ton of different things that can impede it.
well, i know i'm 2800 mhz stable on my 3000+, folding all day long, running real smooth... but i'd like more than just 55 mhz for going through the trouble of water cooling
