how high can i get with a 3200+
xFuryofFivex
i have an AMD 64 3200+ socket 754 1mb L2 cache
i know how to OC it alittle bit... ive heard cases where people have gotten it past 2.4
i can only get it to at the moment 2.299ghz or 2299mhz
here is my motherboard. i think the multipier is locked, im gonna check ASUS now to see if there is any bios updates.(ok checked and i believe there highest is 1005, odd cuz cpuz said i had 1006)
motherboard
http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-490&depa=1
here is my ram
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-305&depa=1
here the cpuz reading if it will help
http://www.geocities.com/gfyfury/1.JPG
http://www.geocities.com/gfyfury/2.jpg
That mobo isn't an overclocker at all. Pick up a DFI Lanpart UT and see how far you can take it. Also, that RAM isn't overclocking RAM in the least, so that is probably hitting its limit as well. As for the multiplier, it's locked upwards, but you can lower it down more.
will lowering it help me go alittle higher? not too experienced in overclocking processors heh ,.if the ram is at 191.fsb couldnt it go a little higher
all ram has its max, u have to change the vdimm and vcore a tad to get it higher. watch the heat.
ok, will putting the multipliers down help me get a little more... or will that make it worse
it actually feels like its going faster..i had the ram at i think 2:1 setting and it felt like the cimputer was feeling a little sluggish.. i put it to 5:3 and it now seems like its moving alot faster
You need to do some research and read around the forums, etc. All the information you want is probably even on stickies in the OC&C forum.
Lowering the multiplier will allow you to get a higher FSB, but this is only worth it if your RAM can handle it. The reason most people buy a 3200 instead of a 3000 is for getting the higher multiplier, so there's really no reason for you to drop it.
It should feel faster going from 2:1 to 5:3. If you look at your CPU-Z now, you will notice your RAM is going faster. It's rated for 3200 speeds at stock voltage and stock timings, so there's no reason why you wouldn't be able to hit 200mhz+ with it. Just play around with the divider, voltages and timings.
Overclocking is just a matter of finding the right combination between HTT, divider, voltages, timings. There's nothing set in stone as to how your system will perform, you just have to fiddle around enough to find out for yourself.
ok... with that said... this motherboard doesnt let me downclock the mutliplier... or i just cant find it
i had to put the clockspeed down to 2299 because i was getting alot of messed up images in a demo i was tryin to play.
There are programs to do it from within Windows.
Read the stickies :rolleyes: Honestly, that's what they're there for....the guide in my sig is in one of them. I suggest you give it a read (either the thread in my sig, or the actual post in the sticky).
